Deletes a range of aggregated IP addresses in an OSPF area.
| area-identifier | Specifies an OSPF area. |
| ip-address | Specifies an IP address. |
| ip-mask | Specifies a subnet mask. |
| ipNetmask | Specifies IP address / Netmask. |
N/A.
Not applicable.
The following command deletes an aggregated IP address range:
configure ospf area 1.2.3.4 delete range 10.1.2.0/24
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
